DJ-70
DJ-70
DJ-70
24 Voices
31 Parts
LPF / HPF / BPF
Envelope -
2 EGs
8-track Sequencer
Tue, 12/24/2019 - 10:02
1992
Roland DJ-70
Roland DJ-70 User Manual
ROLAND DJ-70 by Marians
CABIDE DJ NO DJ 70 ROLAND.mp4
vascotinh
http://www.vintagesynth.com/roland/dj-70
Prelude & Fugue For Korg ER-1 Drum Machi...
Today 10:42 PM
Morphor Echon 6 BBD Resonator Synthesize...
Today 10:42 PM
Hans Zimmer’s CHOOIR Choral Instrument N...
Today 10:08 PM
Sample Mapping And Multisample Creation ...
Today 10:08 PM
FSK Audio release QRonicle
Today 06:00 PM
Today 05:29 PM
Rob Papen launch eXplorer 11
Today 04:57 PM
UVI release Orchestral Suite 2
Today 04:57 PM
Nugen Audio update DialogCheck
Today 04:57 PM
