DJ-70
DJ-70
DJ-70
24 Voices
31 Parts
LPF / HPF / BPF
Envelope -
2 EGs
8-track Sequencer
Tue, 12/24/2019 - 10:02
1992
Roland DJ-70
Roland DJ-70 User Manual
ROLAND DJ-70 by Marians
CABIDE DJ NO DJ 70 ROLAND.mp4
vascotinh
