SP-404
SP-404
SP-404
12
MIDI In
Pattern Sequencer
Patterns -
96 (12 patterns x 8 banks)
29 types
Tue, 11/19/2019 - 12:42
2005
Roland SP-404
Roland SP404 Sampler Demo
PMTVUK
Olby
DDMF release OberComp
Today 12:31 PM
Groove Synthesis release 3rd Wave Termin...
Today 12:31 PM
UJAM release Beatmaker & Usynth Bounce
Today 12:31 PM
Erica Synths reveal the Konstrukt-8 Asse...
Today 12:31 PM
ADDAC System expand the Four String Seri...
Today 12:31 PM
MOTU introduce the OctaLite
Today 12:31 PM
Roland update the TD-07 V-Drums line-up
Today 12:31 PM
New Waldorf Crema Is A Compact String & ...
Today 12:31 PM
Behringer Teases Knockoff Of Classic E-m...
Today 12:31 PM
