Vcps8 not working & strange behaviour
If you did indeed plug it in backwards there will probably be a number of parts damaged. The 7805 regulator and all of the op amps do not tolerate reverse voltage, so there is a good chance that one or more are toast. IC 3, 13, and 14 may be ok since ...
https://electro-music.com/forum/viewtopi...103#456103
