JD-XA
JD-XA
JD-XA
Two LFOs per analog part
MIDI In/Out, USB
16-track Sequencer
64 Preset Patterns
Thu, 09/19/2019 - 12:28
Roland JD-XA
JD-XA
OWNER'S MANUALS
RolandChannel
Today 12:43 PM
Today 12:43 PM
Raiju from fedDSP
Today 12:43 PM
Today 12:43 PM
reFX introduce Rippler
Today 12:43 PM
Roland celebrate 808 Day
Today 12:43 PM
Today 12:43 PM
Today 12:43 PM
Today 12:43 PM
