JD-XA
JD-XA
JD-XA
Two LFOs per analog part
MIDI In/Out, USB
16-track Sequencer
64 Preset Patterns
Thu, 09/19/2019 - 12:28
Roland JD-XA
JD-XA
OWNER'S MANUALS
RolandChannel
Nobels REV-mini pedal: New 3-in-1 Stereo...
Today 09:55 AM
Suno Studio 2.0: MIDI, a Chat Bar, and C...
Today 09:55 AM
Big Guitar Tone 2026: Why Does a Guitar ...
Today 09:55 AM
Today 09:55 AM
Today 09:55 AM
Today 09:55 AM
Today 09:55 AM
Today 09:55 AM
Today 09:55 AM
