JD-XA
JD-XA
JD-XA
Two LFOs per analog part
MIDI In/Out, USB
16-track Sequencer
64 Preset Patterns
Thu, 09/19/2019 - 12:28
Roland JD-XA
JD-XA
OWNER'S MANUALS
RolandChannel
Today 01:37 PM
The M-VAVE FM-1 Frenzy Has Sound Designe...
Today 01:37 PM
Today 01:37 PM
Today 01:37 PM
Today 12:15 PM
Softube Limit Pro and Limit Go: Versatil...
Today 12:15 PM
Mike Beigel: 1947–2026
Today 12:15 PM
Baby Audio announce HyperWarp
Today 12:15 PM
Today 12:15 PM
