JD-XA
JD-XA
JD-XA
Two LFOs per analog part
MIDI In/Out, USB
16-track Sequencer
64 Preset Patterns
Thu, 09/19/2019 - 12:28
Roland JD-XA
JD-XA
OWNER'S MANUALS
RolandChannel
Today 06:00 AM
Today 06:00 AM
Today 06:00 AM
Today 06:00 AM
Strymon launch the La Brea
Today 06:00 AM
Sync Audio release MegaMorph
Today 06:00 AM
Today 06:00 AM
Polarity-MEQ, GRNi Lite, Lega Effect: Fr...
Today 02:16 AM
Ambient Machines: 5 Synths and Devices f...
Today 02:16 AM
