Pulse 2
Pulse 2
Pulse 2
Up to eight note polyphony
3 Analog Oscillators
Filter -
Two
Two ADSR Envelopes
Mon, 09/09/2019 - 12:15
2013
Waldorf Pulse 2
Waldorf Pulse 2 Manual
Waldorf Pulse 2 - demo
Alba Ecstasy
fedDSP release quadCHO
Yesterday 09:08 PM
Yesterday 07:56 PM
Yesterday 07:56 PM
Yesterday 07:56 PM
Yesterday 07:56 PM
Yesterday 07:56 PM
Yesterday 07:56 PM
Yesterday 07:56 PM
Yesterday 06:44 PM
