JD-XA
JD-XA
JD-XA
Two LFOs per analog part
MIDI In/Out, USB
16-track Sequencer
64 Preset Patterns
Thu, 09/19/2019 - 12:28
Roland JD-XA
JD-XA
OWNER'S MANUALS
RolandChannel
fedDSP release quadCHO
Today 09:08 PM
Today 07:56 PM
Today 07:56 PM
Today 07:56 PM
Today 07:56 PM
Today 07:56 PM
Today 07:56 PM
Today 07:56 PM
Today 06:44 PM
