Pulse 2
Pulse 2
Pulse 2
Up to eight note polyphony
3 Analog Oscillators
Filter -
Two
Two ADSR Envelopes
Mon, 09/09/2019 - 12:15
2013
Waldorf Pulse 2
Waldorf Pulse 2 Manual
Waldorf Pulse 2 - demo
Alba Ecstasy
Today 03:37 PM
Today 03:37 PM
Polyend introduce the Loop
Today 03:37 PM
Today 03:37 PM
SoundBridge 3.2.0 arrives
Today 03:37 PM
Today 03:37 PM
Today 03:37 PM
New Forum, Elektronmods, For Unofficial ...
Today 03:37 PM
Against the Grain: Best Granular Synths ...
Today 02:26 PM
