JD-XA
JD-XA
JD-XA
Two LFOs per analog part
MIDI In/Out, USB
16-track Sequencer
64 Preset Patterns
Thu, 09/19/2019 - 12:28
Roland JD-XA
JD-XA
OWNER'S MANUALS
RolandChannel
The 7 Weirdest NAM Captures You Can Down...
Today 12:37 PM
Today 11:49 AM
GForce relaunch with new website, subscr...
Today 11:49 AM
Today 11:49 AM
Groove Synthesis Intros 3rd Wave Termina...
Today 11:12 AM
Today 08:07 AM
Today 08:07 AM
Today 08:07 AM
Today 08:07 AM
