JD-XA
JD-XA
JD-XA
Two LFOs per analog part
MIDI In/Out, USB
16-track Sequencer
64 Preset Patterns
Thu, 09/19/2019 - 12:28
Roland JD-XA
JD-XA
OWNER'S MANUALS
RolandChannel
Today 04:42 PM
Today 04:42 PM
Today 04:42 PM
Today 04:42 PM
Today 04:42 PM
Strymon launch the La Brea
Today 04:42 PM
Sync Audio release MegaMorph
Today 04:42 PM
Today 04:08 PM
Today 04:08 PM
