Pulse 2
Pulse 2
Pulse 2
Up to eight note polyphony
3 Analog Oscillators
Filter -
Two
Two ADSR Envelopes
Mon, 09/09/2019 - 12:15
2013
Waldorf Pulse 2
Waldorf Pulse 2 Manual
Waldorf Pulse 2 - demo
Alba Ecstasy
Today 03:28 AM
Today 03:28 AM
Voxis from CEDAR Audio
Yesterday 11:47 PM
Yesterday 11:47 PM
Arturia release Pure Sub
Yesterday 11:47 PM
Yesterday 11:47 PM
Yesterday 09:26 PM
Yesterday 09:26 PM
Yesterday 09:26 PM
