JD-XA
JD-XA
JD-XA
Two LFOs per analog part
MIDI In/Out, USB
16-track Sequencer
64 Preset Patterns
Thu, 09/19/2019 - 12:28
Roland JD-XA
JD-XA
OWNER'S MANUALS
RolandChannel
Finalist 2 from Tim Exile
Today 04:56 PM
Today 04:56 PM
Today 04:56 PM
Today 04:56 PM
Today 04:56 PM
Polyend introduce the Loop
Today 04:56 PM
Today 04:56 PM
Vintage Synth Review: The E-Mu Emax II S...
Today 04:56 PM
Today 04:56 PM
