JD-XA
JD-XA
JD-XA
Two LFOs per analog part
MIDI In/Out, USB
16-track Sequencer
64 Preset Patterns
Thu, 09/19/2019 - 12:28
Roland JD-XA
JD-XA
OWNER'S MANUALS
RolandChannel
Today 04:13 AM
iFi audio reveal the GR2 MT
Today 04:13 AM
Today 04:13 AM
Today 04:13 AM
Today 04:13 AM
Today 04:13 AM
Today 04:13 AM
Vinyl DJ 2026: Essential Gear for Perfec...
Today 03:00 AM
Stylophone Mini: Honey I Shrunk the Styl...
Today 03:00 AM
