Pulse 2
Pulse 2
Pulse 2
Up to eight note polyphony
3 Analog Oscillators
Filter -
Two
Two ADSR Envelopes
Mon, 09/09/2019 - 12:15
2013
Waldorf Pulse 2
Waldorf Pulse 2 Manual
Waldorf Pulse 2 - demo
Alba Ecstasy
Today 06:17 PM
5 of the Best Analog Polysynths: Tones S...
Today 06:17 PM
Today 06:17 PM
Today 06:17 PM
The DMNO ON from UDO Audio
Today 06:17 PM
Today 06:17 PM
Today 06:17 PM
Today 06:17 PM
Today 06:17 PM
