Pulse 2
Pulse 2
Pulse 2
Up to eight note polyphony
3 Analog Oscillators
Filter -
Two
Two ADSR Envelopes
Mon, 09/09/2019 - 12:15
2013
Waldorf Pulse 2
Waldorf Pulse 2 Manual
Waldorf Pulse 2 - demo
Alba Ecstasy
Mike Beigel: 1947–2026
Today 04:21 PM
Baby Audio announce HyperWarp
Today 04:21 PM
Today 04:21 PM
Arturia update the AstroLab
Today 04:21 PM
Today 04:21 PM
Today 04:21 PM
fedDSP release quadCHO
Today 04:21 PM
Bass++ Mods
Today 03:09 PM
Today 03:09 PM
