JD-XA
JD-XA
JD-XA
Two LFOs per analog part
MIDI In/Out, USB
16-track Sequencer
64 Preset Patterns
Thu, 09/19/2019 - 12:28
Roland JD-XA
JD-XA
OWNER'S MANUALS
RolandChannel
Today 08:20 PM
Today 07:41 PM
Today 07:41 PM
Today 07:41 PM
Today 06:52 PM
Today 06:52 PM
Today 06:17 PM
5 of the Best Analog Polysynths: Tones S...
Today 06:17 PM
Today 06:17 PM
