Pulse 2
Pulse 2
Pulse 2
Up to eight note polyphony
3 Analog Oscillators
Filter -
Two
Two ADSR Envelopes
Mon, 09/09/2019 - 12:15
2013
Waldorf Pulse 2
Waldorf Pulse 2 Manual
Waldorf Pulse 2 - demo
Alba Ecstasy
Melbourne Instruments ROTO-CONTROL: 60+ ...
Today 05:14 AM
music2me: Online Music School with Live ...
Today 05:14 AM
Today 05:14 AM
Today 05:14 AM
Today 05:14 AM
Today 05:14 AM
Today 05:14 AM
Strymon launch the La Brea
Today 05:14 AM
Sync Audio release MegaMorph
Today 05:14 AM
