| 0 | 0 | ||
I'm looking for a fairly slow (AD only) envelope generator (or function generator?). My requirements are: - Slow. 3-5 minutes per stage would be ideal. - Timings modulable through CV (or at least a way to clock it slower - I don't need specific timings for attack and decay individually, just applying e.g. a 0.9x transform would be fine). - Slope customisation. At the very least, I'd like both of the attack and decay to be logarithmic (as that's the main one I'm after), but customisation would be ideal. I could also live with an exponential attack and a logarithmic decay. - Bonus points if it's easy to loop.
Instruo's Cnōc is almost perfect. The only issue I have is that the slopes are either both linear, or log for attack (good!) and exp for decay (that's where the issue is for me).
Another candidate I have in mind is ALM Busy Circuit's Quaid Megaslope, which would most likely fit the bill (I'm not 100% sure about the slowest it can run though), but it's a massive module for what I'm after.
Any recommendations?
