Pulse 2
Pulse 2
Pulse 2
Up to eight note polyphony
3 Analog Oscillators
Filter -
Two
Two ADSR Envelopes
Mon, 09/09/2019 - 12:15
2013
Waldorf Pulse 2
Waldorf Pulse 2 Manual
Waldorf Pulse 2 - demo
Alba Ecstasy
Today 01:37 PM
The M-VAVE FM-1 Frenzy Has Sound Designe...
Today 01:37 PM
Today 01:37 PM
Today 01:37 PM
Today 12:15 PM
Softube Limit Pro and Limit Go: Versatil...
Today 12:15 PM
Mike Beigel: 1947–2026
Today 12:15 PM
Baby Audio announce HyperWarp
Today 12:15 PM
Today 12:15 PM
