Pulse 2
Pulse 2
Pulse 2
Up to eight note polyphony
3 Analog Oscillators
Filter -
Two
Two ADSR Envelopes
Mon, 09/09/2019 - 12:15
2013
Waldorf Pulse 2
Waldorf Pulse 2 Manual
Waldorf Pulse 2 - demo
Alba Ecstasy
Latest FM-1 Firmware Lets You Load 4 Syn...
Today 01:10 AM
It Looks Like Behringer Wants To Copy Th...
Today 01:10 AM
New Plugin Recreates Classic Lexicon 224...
Yesterday 11:58 PM
Synth Rig USB-C Hub Recommendation
Last Post: ss_admin_user
Yesterday 11:24 PM
Synth Rig USB Hub Recommendation
Yesterday 09:30 PM
DDMF release OberComp
Yesterday 08:54 PM
The Best Guitar Amp for Beginners 2027: ...
Yesterday 08:16 PM
Yesterday 02:29 PM
The Best Studio Gear 2026 for Recording ...
Yesterday 02:29 PM
