Pulse 2
Pulse 2
Pulse 2
Up to eight note polyphony
3 Analog Oscillators
Filter -
Two
Two ADSR Envelopes
Mon, 09/09/2019 - 12:15
2013
Waldorf Pulse 2
Waldorf Pulse 2 Manual
Waldorf Pulse 2 - demo
Alba Ecstasy
Yesterday 10:00 PM
Yesterday 10:00 PM
Yesterday 10:00 PM
I/O Music release Talkback
Yesterday 10:00 PM
Raiju from fedDSP
Yesterday 10:00 PM
Yesterday 10:00 PM
reFX introduce Rippler
Yesterday 10:00 PM
Roland celebrate 808 Day
Yesterday 10:00 PM
pixels & scanlines
Yesterday 06:56 PM
