Pulse 2
Pulse 2
Pulse 2
Up to eight note polyphony
3 Analog Oscillators
Filter -
Two
Two ADSR Envelopes
Mon, 09/09/2019 - 12:15
2013
Waldorf Pulse 2
Waldorf Pulse 2 Manual
Waldorf Pulse 2 - demo
Alba Ecstasy
Today 03:40 PM
Yorkville launch the EL24S
Today 03:40 PM
Today 03:40 PM
Today 03:40 PM
VAEMI announce the Synterra
Today 03:40 PM
AudioRoute from Arvital Audio
Today 03:40 PM
Today 03:40 PM
SSL 360° gets a major update
Today 03:40 PM
How Streaming Changed the Way We Produce...
Today 12:40 PM
