Roland JX-8p boot problem with random led blinking at key mode
Help! What happened: I’ve cleaned output level switch because this is a common issue with output problems. until the the synth worked fine. After reassembling it doesn’t boot and the leds around key mode flash randomly.
I’ve googled a lot and there are some people having the exact problem, but nobody posted a solution.
PSU works perfect.
Cables are in right positions (and yes, CN2 as well).
Before i try to find a bad one in between those thousands of solder joints, maybe somebody has an idea?
submitted by /u/Hopeful-Data717
