Seeking advice on using a 16 channel mixer with a eurorack system.
Currently Im running the four outputs of a quad vca and the outputs of clouds to the mixer, I know this isn't ideal but Im curious what equipment and routing you guys use to perform and record. Is there a solution to sending multiple eurorack voices to a mixer or do mix inside the eurorack then send out a stereo mix? Mostly I have outboard delays and reverbs I want to use on as send/return.
submitted by /u/Hiddeninthou8
