Accessing Behringer Semi-Modular back panel when racked?
Hey all. I've got a Neutron and a K2 Behringer Semi Modular and recently took the plunge and bought Beads and a 6U case that will arrive soon.
After pulling the trigger on the case I've realised I will lose access to the USB, MIDI thru and separate input/output jacks of the Behringers if I rack them and I do use these all the time. I get that I can use the front mounted MIDI inputs however I like the fact that they come up as named devices in my DAW rather than just MIDI device 1 2 3 etc and it's one cable each for in/out.
I'm surprised more people didn't have the same question online! I dug up a separate module that brings the back panel into a 1HP thing you can have next to it but then I feel aggrieved at having to buy ANOTHER module to make something that already works, work!
EDIT: I wonder if I can just detatch the PCB in the original case and mount it inside the Euro case?
submitted by /u/friendlysaxoffender
