Vermona Mono Lancet
Vermona Mono Lancet
Vermona Mono Lancet
1 VCO
Slope -
24dB Slope (4-pole)
1 VCA with ADSR
Thu, 05/06/2021 - 09:33
Vermona Mono Lancet
Mono Lancet ’15 User Guide
User Guide
Syntza
INHALTVIDEO
VSE Rating
5 of the Most Unique-Sounding Synths
Today 04:10 PM
Best Guitar Stands: 5 Reliable Choices f...
Today 04:10 PM
Producing Trap Beats: This Gear Is a Per...
Today 04:10 PM
Today 04:10 PM
Today 04:10 PM
Steinberg Celebrates 30 Years Of VSTs Wi...
Today 04:10 PM
New Plugin, I Am Choir, Transforms Your ...
Today 04:10 PM
William Orbit Has Died At The Age Of 69
Today 04:10 PM
SonicLAB: Genki Katla With Venus Theory ...
Today 04:10 PM
