Vermona Mono Lancet
Vermona Mono Lancet
Vermona Mono Lancet
1 VCO
Slope -
24dB Slope (4-pole)
1 VCA with ADSR
Thu, 05/06/2021 - 09:33
Vermona Mono Lancet
Mono Lancet ’15 User Guide
User Guide
Syntza
INHALTVIDEO
VSE Rating
