Quantum
Quantum
Quantum
8 Voices
8 Parts
3 stereo digital oscillators
6 LFOs
MIDI IN, OUT, THRU
4 GB Internal Flash memory
Fri, 04/09/2021 - 08:49
Waldorf Quantum
Waldorf Quantum Demo
Hunart©
Today 03:46 PM
Today 03:46 PM
Today 03:46 PM
Today 03:46 PM
Am I Audio launch I Am Choir
Today 03:46 PM
Today 03:46 PM
Today 03:46 PM
Peak Tamer from Nicky Howard
Today 03:02 PM
Rhodes launch Rhodes Clav Pro
Today 03:02 PM
