Quantum
Quantum
Quantum
8 Voices
8 Parts
3 stereo digital oscillators
6 LFOs
MIDI IN, OUT, THRU
4 GB Internal Flash memory
Fri, 04/09/2021 - 08:49
Waldorf Quantum
Waldorf Quantum Demo
Hunart©
Today 11:31 AM
UVI Falcon 2027 Flies The Nest with More...
Today 11:31 AM
ADAM Audio Sub10 PRO and Sub8 PRO: 2 New...
Today 11:31 AM
Teenage Engineering Wants to Stop Making...
Today 11:31 AM
Sync Audio release MegaMorph
Today 11:31 AM
Today 11:31 AM
Today 11:31 AM
Today 11:31 AM
Today 11:31 AM
