Quantum
Quantum
Quantum
8 Voices
8 Parts
3 stereo digital oscillators
6 LFOs
MIDI IN, OUT, THRU
4 GB Internal Flash memory
Fri, 04/09/2021 - 08:49
Waldorf Quantum
Waldorf Quantum Demo
Hunart©
Today 05:58 AM
Mike Beigel: 1947–2026
Today 05:58 AM
Baby Audio announce HyperWarp
Today 05:58 AM
Today 05:58 AM
Arturia update the AstroLab
Today 05:58 AM
Today 05:58 AM
Today 05:58 AM
STR-500 Gestural Granular Synthesizer : ...
Today 05:58 AM
Today 03:37 AM
