Quantum
Quantum
Quantum
8 Voices
8 Parts
3 stereo digital oscillators
6 LFOs
MIDI IN, OUT, THRU
4 GB Internal Flash memory
Fri, 04/09/2021 - 08:49
Waldorf Quantum
Waldorf Quantum Demo
Hunart©
Synth Trends of Superbooth 2026: Putting...
Today 01:41 PM
Best Gigging Guitars: 5 Versatile Option...
Today 01:41 PM
Soundfonts come to Korg's Drumlogue (& m...
Today 01:41 PM
Today 12:18 PM
Harley Benton MV-4JB Plus BassTheWorld: ...
Today 12:18 PM
Buzzing Bugs Audio Devices introduce the...
Today 12:18 PM
Music Expo (San Francisco) becomes MONO ...
Today 12:18 PM
Today 10:23 AM
Taylor Next Generation: Four Grand Conce...
Today 10:23 AM
