Quantum
Quantum
Quantum
8 Voices
8 Parts
3 stereo digital oscillators
6 LFOs
MIDI IN, OUT, THRU
4 GB Internal Flash memory
Fri, 04/09/2021 - 08:49
Waldorf Quantum
Waldorf Quantum Demo
Hunart©
Yesterday 10:45 PM
reFX introduce Rippler
Yesterday 10:45 PM
New Microtonal Soundscape Synthesizer Fo...
Yesterday 10:45 PM
Sonuscore Intros The Sculpture Metallic ...
Yesterday 10:45 PM
Bio-Interactive Generative Synthesizer :...
Yesterday 10:45 PM
Roland celebrate 808 Day
Yesterday 08:20 PM
Yesterday 08:20 PM
Yesterday 08:20 PM
Yesterday 08:20 PM
