Quantum
Quantum
Quantum
8 Voices
8 Parts
3 stereo digital oscillators
6 LFOs
MIDI IN, OUT, THRU
4 GB Internal Flash memory
Fri, 04/09/2021 - 08:49
Waldorf Quantum
Waldorf Quantum Demo
Hunart©
Today 04:42 PM
Today 04:42 PM
Today 04:42 PM
iFi audio reveal the GR2 MT
Today 04:42 PM
Today 04:42 PM
Today 04:42 PM
Today 04:42 PM
Gibson Original Collection with HiFi DNA...
Today 01:40 PM
Guitar Journal: Boss Katana 10th Anniver...
Today 01:40 PM
