Quantum
Quantum
Quantum
8 Voices
8 Parts
3 stereo digital oscillators
6 LFOs
MIDI IN, OUT, THRU
4 GB Internal Flash memory
Fri, 04/09/2021 - 08:49
Waldorf Quantum
Waldorf Quantum Demo
Hunart©
Most simple VCF on earth
Today 11:10 PM
Today 10:15 PM
Arturia update the AstroLab
Today 10:15 PM
Today 09:28 PM
Today 09:28 PM
fedDSP release quadCHO
Today 09:28 PM
Today 09:28 PM
Today 09:28 PM
Today 09:28 PM
