Quantum
Quantum
Quantum
8 Voices
8 Parts
3 stereo digital oscillators
6 LFOs
MIDI IN, OUT, THRU
4 GB Internal Flash memory
Fri, 04/09/2021 - 08:49
Waldorf Quantum
Waldorf Quantum Demo
Hunart©
Manley Dual Channel EQ Series: The Retur...
Yesterday 11:59 PM
Neumann U87 Alternatives: Workhorse Cond...
Yesterday 11:59 PM
NAM A2 Pedals & Software: This Gear Supp...
Yesterday 11:59 PM
Yesterday 11:59 PM
Yesterday 11:59 PM
Yesterday 11:59 PM
DT 275 Pro from beyerdynamic
Yesterday 11:59 PM
Yesterday 11:59 PM
Arturia’s Summer Sale now live
Yesterday 11:59 PM
