Quantum
Quantum
Quantum
8 Voices
8 Parts
3 stereo digital oscillators
6 LFOs
MIDI IN, OUT, THRU
4 GB Internal Flash memory
Fri, 04/09/2021 - 08:49
Waldorf Quantum
Waldorf Quantum Demo
Hunart©
Today 01:15 AM
Most simple VCF on earth
Yesterday 11:10 PM
Yesterday 10:15 PM
Arturia update the AstroLab
Yesterday 10:15 PM
Yesterday 09:28 PM
Yesterday 09:28 PM
fedDSP release quadCHO
Yesterday 09:28 PM
Yesterday 09:28 PM
Yesterday 09:28 PM
