Quantum
Quantum
Quantum
8 Voices
8 Parts
3 stereo digital oscillators
6 LFOs
MIDI IN, OUT, THRU
4 GB Internal Flash memory
Fri, 04/09/2021 - 08:49
Waldorf Quantum
Waldorf Quantum Demo
Hunart©
GearExpo UK: Interfaces & Mic Preamp Upd...
Today 06:32 PM
Fender Studio Pro 8.1 arrives
Today 06:32 PM
bigBASS from fedDSP
Today 06:32 PM
Announcement from Wayne Jones Audio
Today 06:32 PM
Audeze announce the MM-520
Today 06:32 PM
IK Multimedia’s ARC On-Ear gains IEM sup...
Today 06:32 PM
GearExpo UK: Keyboard & Synth Update
Today 06:32 PM
Decksaver’s Sping 2026 Drop
Today 05:58 PM
Spitfire Audio bring Originals to Akai M...
Today 05:58 PM
