Quantum
Quantum
Quantum
8 Voices
8 Parts
3 stereo digital oscillators
6 LFOs
MIDI IN, OUT, THRU
4 GB Internal Flash memory
Fri, 04/09/2021 - 08:49
Waldorf Quantum
Waldorf Quantum Demo
Hunart©
AJH Synth V-Scale In Action : Watch it c...
Today 01:21 AM
BOOM Library Announces UBERBASS : A bass...
Today 01:21 AM
Yesterday 11:13 PM
Yesterday 11:13 PM
Yesterday 08:48 PM
Yesterday 08:48 PM
Sony announce the ECM-AX10
Yesterday 08:48 PM
10K Audio update Gyro
Yesterday 08:48 PM
Yesterday 08:48 PM
