Quantum
Quantum
Quantum
8 Voices
8 Parts
3 stereo digital oscillators
6 LFOs
MIDI IN, OUT, THRU
4 GB Internal Flash memory
Fri, 04/09/2021 - 08:49
Waldorf Quantum
Waldorf Quantum Demo
Hunart©
sE Electronics V8: A Premium Stage Mic w...
Today 11:37 AM
Focusrite, Novation, and ADAM Audio: Stu...
Today 11:37 AM
Today 11:37 AM
Today 11:37 AM
Today 11:37 AM
Today 11:37 AM
Today 11:37 AM
Today 11:37 AM
Finalist 2 from Tim Exile
Today 11:37 AM
