1 VCA with ADDSR envelope
Thu, 03/04/2021 - 08:59
2016
WALDORF MOD1 USERMANUAL
Waldorf vcf1 and mod1 test
Stefan Robbers
Today 12:45 AM
Today 12:45 AM
Yesterday 11:51 PM
Yesterday 11:51 PM
Strymon launch the La Brea
Yesterday 11:51 PM
Sync Audio release MegaMorph
Yesterday 11:51 PM
Yesterday 11:51 PM
Yesterday 11:51 PM
Yesterday 11:51 PM
