1 VCO
Saw Up, Square,
1 VCA with Decay envelope
1 unique ARP mode
Fri, 12/04/2020 - 08:52
2017
Bass Bott
Link
cyclone analogic webstore
Arturia launch the AudioFuse Studio Rev2
Yesterday 11:21 PM
Neumann launch the KH 310 II & KH 350
Yesterday 11:21 PM
Readipop & XOX open XOX Studio
Yesterday 10:22 PM
Acon Digital introduce Acoustica 8
Yesterday 10:22 PM
Bjooks Beat Gems to begin shipping
Yesterday 10:22 PM
Sonarworks Autumn Sale
Yesterday 10:22 PM
Celemony Tonalic gains additional Paul K...
Yesterday 10:22 PM
XILS Lab introduce MemoryTone
Yesterday 10:22 PM
Warm Audio unveil the Jude preamps
Yesterday 10:22 PM
