1 VCO
Saw Up, Square,
1 VCA with Decay envelope
1 unique ARP mode
Fri, 12/04/2020 - 08:52
2017
Bass Bott
Link
cyclone analogic webstore
Soundgas Sounds: Latest prize draw annou...
Today 04:35 AM
RME unveil the ADI-2 Pro EX
Today 04:35 AM
Sonuscore release LUX Orchestral Strings...
Today 04:35 AM
Sweetwater Studios announce Guitar Recor...
Today 04:35 AM
GearExpo UK: Microphone Update
Today 04:35 AM
Celemony announce Tonalic ARA support fo...
Today 04:35 AM
Aim Audio’s Essence price drop
Today 04:35 AM
Affordable Tube Amps: The Best All-tube ...
Today 02:11 AM
Sidechain Compression in Techno: 5 Effec...
Today 02:11 AM
