1 VCO
Saw Up, Square,
1 VCA with Decay envelope
1 unique ARP mode
Fri, 12/04/2020 - 08:52
2017
Bass Bott
Link
cyclone analogic webstore
Celemony Tonalic gains additional Paul K...
Today 07:55 AM
XILS Lab introduce MemoryTone
Today 07:55 AM
Warm Audio unveil the Jude preamps
Today 07:55 AM
Sauceware Audio release Scorch 2
Today 07:55 AM
DPA to launch the 6388 Core+
Today 07:55 AM
GameSoundCon 2026
Today 07:55 AM
HeadRush launch the FRFR Cab Series
Today 07:55 AM
BS-203 MacroAcidizer from Born Second
Today 06:22 AM
HEDD Audio update CTRL software
Today 06:22 AM
