1 VCO
Saw Up, Square,
1 VCA with Decay envelope
1 unique ARP mode
Fri, 12/04/2020 - 08:52
2017
Bass Bott
Link
cyclone analogic webstore
Today 01:33 AM
Today 01:33 AM
VAEMI announce the Synterra
Today 01:33 AM
AudioRoute from Arvital Audio
Today 01:33 AM
Today 01:33 AM
SSL 360° gets a major update
Today 01:33 AM
Boris FX reveal Sequoia 2026.5
Today 01:33 AM
Emergence Audio unveil Envoy
Yesterday 10:24 PM
Yesterday 10:24 PM
