1 VCO
Saw Up, Square,
1 VCA with Decay envelope
1 unique ARP mode
Fri, 12/04/2020 - 08:52
2017
Bass Bott
Link
cyclone analogic webstore
Today 03:12 PM
Today 03:12 PM
Today 03:12 PM
Strymon launch the La Brea
Today 03:12 PM
Sync Audio release MegaMorph
Today 03:12 PM
Today 03:12 PM
Today 03:12 PM
Today 03:12 PM
Today 03:12 PM
