1 VCO
Saw Up, Square,
1 VCA with Decay envelope
1 unique ARP mode
Fri, 12/04/2020 - 08:52
2017
Bass Bott
Link
cyclone analogic webstore
bigBASS from fedDSP
Today 11:52 AM
Announcement from Wayne Jones Audio
Today 11:52 AM
Audeze announce the MM-520
Today 11:52 AM
IK Multimedia’s ARC On-Ear gains IEM sup...
Today 11:52 AM
GearExpo UK: Keyboard & Synth Update
Today 11:52 AM
Decksaver’s Sping 2026 Drop
Today 11:52 AM
Spitfire Audio bring Originals to Akai M...
Today 11:52 AM
GearExpo UK: Monitor Update
Today 11:17 AM
Soundgas Sounds: Latest prize draw annou...
Today 11:17 AM
