1 VCO
Saw Up, Square,
1 VCA with Decay envelope
1 unique ARP mode
Fri, 12/04/2020 - 08:52
2017
Bass Bott
Link
cyclone analogic webstore
Yesterday 10:00 PM
Yesterday 10:00 PM
Yesterday 10:00 PM
I/O Music release Talkback
Yesterday 10:00 PM
Raiju from fedDSP
Yesterday 10:00 PM
Yesterday 10:00 PM
reFX introduce Rippler
Yesterday 10:00 PM
Roland celebrate 808 Day
Yesterday 10:00 PM
pixels & scanlines
Yesterday 06:56 PM
